The Elithion Lithiumate BMS manual describes the charging phases of CCCV charging here, and with the attached figure. I understand the CC phase; I'm interested in understanding the CV part of the charging phase, where the voltage is held constant and the current is tapered off exponentially. Is anyone allowing their Elithion to control their charger?
I'm puzzled by their statement at the bottom of their web page,
Presumably the BMS must know the max value of each charger make/model that it is communicating with. I guess I'll have to conduct an experiment, and tell the BMS that I have a different charger, and watch the CAN messages to see if it changes the output current message.
How can it not be necessary? How else is the current going to exponentially decay unless the charger is told explicitly to do so? All throughout their page on charging they advocate a dumb charger and letting the BMS do the thinking. And in order for the BMS to get it right then it must know what the charger is capable of.If the charger is capable of current control, you may also set up a way for the BMS to tell the charger the maximum allowed current, either through the CCL line or through the CCL data in the standard CAN messages.
That is not absolutely necessary, though.
