Hello friends I hope someone can help me in my dilemma.
I changed the cells in my hybrid scooter battery pack and when im trying to turn on from mosfet switch it remains blinking red.
The battery pack is 10 cells 3.7v at 31Ah.Has and integrated bms and 9 cells have a board between terminals.I removed the pcb chips and installed on the new cells.The bms has a can bus system also which communicates with the main ecu.
But im stuck the voltage is there but the bms is not giving the signal to swith on the battery and turn the led to green.
The battery is installed in the Hybrid scooter MP3 made by Piaggio.
I have more documentation if needed.
Hope I will have some feedback because my hopes are diminishing
