Hi, Im from Norway, sorry for the spelling.
I have bougth a Elcon Charger that should be possible to change the output voltage acording to this information from Elcon. But when I powered the charger (AC) this is not what happen. On my charger the LED flashes red/green/red/green/red/green very fast and then beegan too flash green. If i releese the button after 8 green flash, the LED continue too flash in the same interval. And I am not shure that I have the changed too Selection 8
Has anyone did this with a Elcon charger?
This is how too from Elcon
How do I change the selection on my charger?
When the charger is powered up, the red LED blinks from 1 to 10 times to show the current selection. To change this selection, peel off the left edge of the Model Number label (nearest the end of the charger) and look through the small oval hole underneath. There should be a black plastic button near the surface, or a metal button further down below. For the metal button you will need to use a wooden or plastic stick to hold it down. Hold down the selection button while powering up the charger. The green LED will start blinking slowly. Count the number of blinks (1 to 10) that you need and release the selection button. The red LED will blink the same number of times to confirm your selection and then start charging.
