G
Guest
·Any charger that will charge up a single 100 AH Prismatic Cell? I need a way to charge up single batteries to bring a few up to balance with the others. If it takes a month so be it. Since I have no way to bottom balance or discharge my batteries properly I will try to do a top charge. Any ideas? I see no chargers on the list anywhere to do this.
Either I need a way to discharge or to charge up single batteries to a specified voltage.
Also does anyone know what the resting voltage for the lithiums should be?
Pete
With out a CC CV charger I am unable to control the charge. I pulled a battery to 4.1 volts but as soon as it was removed from the charger the battery went back down to 3.37 volts. I have no way to hold a voltage while the amperage slowly drops while the battery charges. Mine just increases the voltage as the amperage drops and it will go into over load if not watched.
I need a proper single charger. Got one?
Pete
