I have a 300Ah ~13V battery in my campervan. In the winter, solar power is insufficient.
I would like to use public EV charge stations to charge my battery at 0.5C = 150A , ~2kW.
I could buy a gasoline generator, but I'd still need to convert 230VAC to 13.5V @ 2kW, and buy a generator, which is noisy, more expensive per kWh, and generally less attractive than quiet EV charging.
Are there any plug-and-play solutions that can communicate with the charge station, and possibly convert the voltage into low-voltage range, e.g. 48V (which I can then convert to ~13.5V).
I'm not sure what words to search for in the forum.
I welcome any ideas!
