Your bms might get upset if it sees one cell ramping up in charge while the other cell friends weren't invited to the party.
For a number of reasons, including getting killed, disconnect all the cells, then constant current charge them, one ar a time, physically removed from the pack, to 3.5V.
Miss the window to shut off the charging and you'll have the 4th of July in your garage.
I would do this kind of futzing outside, away from everything, including the pack of other cells. Water hose nearby and ready to use.
What you're doing is risking electrocution and is a major fire risk, especially with dead cells.
