Hi All, four years ago I converted my Grasshopper lawnmower from gas to electric. I am using 15 Calb 180Ah Li-ion cells, an Elcon charger and CelanPowerAuto BMS v2 which I purchased from Lithium Storage. I also have a Link 10 battery monitor that I use to watch the Amphr's in and out. This has worked fairly well for the last four years with a few minor charging/discharge issues.
My current problem is that the charger is shutting off due to one cell getting to high voltage on the BMS before the charger has had a chance to EQ all the cells. I usually run the batteries to about 80-100 Amphrs discharge level and then recharge. With the BMS shutting the charger off early, the Link10 indicates there is still 15-20 Amphrs of charging left.
I thought the BMS was the problem as two of the cell modules have some corrosion on the chips due to condensation. I moved the BMS cell module and the same battery cell caused the BMS high voltage to shut the charger off.
I have tried to contact Lithium Storage and CleanPowerAuto to get a replacement BMS modules with no luck. I am concerned that if I continue to use the mower without fully charging all the cells I am eventually going to ruin the batteries.
Any thoughts on what I can do to correct this situation.
Thanks, Paul
