1 - 5 of 5 Posts
Hey guys!
I am military stationed in Europe. I brought our US spec 2017 Volvo XC90 hybrid with us here to the Deutschland. Trouble is I can't charge the car here. The OEM charge cord (TurboCord - http://www.evsolutions.com/turbocord) doesn't work here and the European cord has a different male connector. The only solution provided by Volvo is to rewire the car.
They only practical way forward I see is to buy a frequency transformer for either the 220v or the 400v outlets and use the US cord; but those are EXPENSIVE!! Thoughts? Suggestions? Looking for any and all ideas!!
The OEM cord lists the required input/output as 120-240v, 12/16amps, 60Hz. So the only issue I see is that European outlets are 50Hz
New to the forum. Thanks for the help!
-Tom
I am in your same boat! Just moved here from TX with the military and can't figure a quick fix for my US spec T8 Xc90 (2017). Contacted local Volvo and got the following:
"The XC90 T8 charging cable for the US version is different than the one for the European model. As we have not had the opportunity to deliver a T8 locally, we do not have an example of the connections. I contacted a colleague who told me to look at this website...
https://www.derladekabelshop.de/brands/dostar/
Here you should be able to find the charging cable by contacting them. Attached is a photo of the item that should work.
I understand that currently the cables are out of stock... therefore you should write them and see if they have a suitable substitute or perhaps they can let you know when they may be in stock again."
I think the 50 Hz is throwing things off as the provided cable is smart enough to know the 240V 16A I'm plugging it into is at 50Hz.
-Mike
Are you trying to charge from a regular wall socket? If you are then you need a EVSE with a J1772 connector on one end and a German 'Schuko' plug on the other... something like this;
http://www.ebay.de/itm/EV-Ladekabel...-5TT3201-1KK81-Schnellladekabel-/122584357758
If you're trying to charge from a 'charging station' then you need a cable with a J1772 connector on one end and a Type 2 'mennekes' plug on the other... something like this;
http://www.ebay.de/itm/1-phasig-32A...de3-7-m-Laenge-Soul-Ampera-Leaf-/121748792533
1 - 5 of 5 Posts
