1 - 14 of 14 Posts
Discussion Starter #1
I am planning my first EV project using a '78 Honda CB400T. It will be 48V with a Mars/Etec style motor. I'm hoping for a 12-15 mile range and a top speed of 50 mph for my commute. My question is about charging. I know using four separate cheaper 12V chargers can work well to keep everything balanced on a low budget, like in this thread:
http://www.diyelectriccar.com/forums/showthread.php?t=47085&highlight=series+parallel+charging
But, what about switching from series to parallel for charging? For driving you would use series for 48V. But for charging you would open the circuits between batteries and reconnect in parallel with a smaller charging circuit. This would keep the batteries perfectly balanced using one 12V higher amp charger, would it not? For the sake of space on a motorcycle, one large charger would take up less space than four smaller ones; plus, it would cost less. Has this been attempted before?
Thanks in advance!
James
hooking/unhooking multiple chargers each night, or switching battery connections, sounds like an incredible waste of time versus the cost of getting a decent production charger. Charging in parallel of one cheap 12v charger would take forever anyway as you can't pump many amps to the batteries.
save your money and time and buy a decent charger.
Discussion Starter #3
Thanks for the advice. What would be the best charger for 48V X 55ah?
I was thinking of putting a battery disconnect between each battery in the traction circuit and switching the parallel charge circuit on with relays. So to charge, switch the 3 battery disconnects off (between the 4 batteries) and flip the "charge" switch that connects the batteries in parallel with relays to the 12V charger. I have all night to charge it up, and with four 55ah batteries I would only need to charge at 10A anyway, as far as I know. I could use a 48V 10A charger (the golf cart chargers I've seen are 13A), or four 10A 12V chargers, or one 40A 12V charger wired in parallel.
Discussion Starter #4
Today I learned about vari-bad-boy chargers, and other similar chargers. These things appeal to me because of their price. I am on a ridiculously tight budget. I understand the risks and attention required while charging, but I'm going to do it anyway.
Instead of buying a variac that is heavy and pricey, has anyone tried making a manually controlled charger out of a 1000W dimmer switch and a bridge rectifier? A dimmer switch is tiny and light - much more appealing for a motorcycle. And 1000W will be lots enough for my purpose. My second question is: at 48V and 10-12A, how big of capacitor will I need (if at all) after the rectifier to smooth things out enough for charging? Will this work or am I out to lunch?
Admin: 'one of many'
I did try using a multi pole break before make rotary switch on my 48v tractor to switch the reading from a volt meter to read individual battery voltages and the pack voltage.
I figured that if it worked then I could use a similar set up to switch for charging voltage so that I could drive in series and charge in parallel.
After a flicks of the switch it shorted and blew up.:eek:
The idea was sound but the switch needed to be a much higher rating with bigger gaps between the break before make wiper.
Better still would be a switch frame with separate switch units stacked up.
G
Guest
After all your troubles of figuring out how to do this and the parts to make it work and the experimenting to make it work you could just go out and buy a single charger new that you don't have to think about. Just plug it in and forget about it. I use a Quickcharge Select-A-Charge 96 volt charger and it works perfect. Not overly expensive and quiet. It shuts down after its done charging. Not the best on board charger for a bike but it would be fine for a home charger. It would charge your pack easy. I think it's like 12 amps. Got mine for $200 bucks.
Why go to all the trouble of doing the switching and and such when you could just plug it in and forget about it. I thought that was one of the best things about an electric vehicle. Just plug it in and go about your business. No worries. No hassles, No headaches, No problems.
Pete :)
In regards to having to disconnect all the batteries in the string (go from series to parallel) for charging, if you are using multiple 12V chargers and they have isolated outputs, then this is not necessary. By isolated, I mean there must be no electrical connection between the DC output side and the AC input. If this is the case, then you can hook one to each of your 12V batteries while they are still in series with each other without worry.
You can get multi-bank isolated 12V chargers for boats, etc, I know you can get ones with four chargers (48V) in one box. Perhaps that is the model you are talking about above, not sure. So essentially it would be "one" charger though electrically it would manage each 12V battery separately.
As variac chargers go, they can be very cheap to build if you can get ahold of an appropriate variac cheaply. They work best when the line voltage going into the variac is similar to the battery voltage (because you get the most power that way) but will output anywhere from zero to the maximum voltage you can safely wire the variac for given input voltage, which is at least 100% and commonly 125% of line voltage. So if you were to find a 20A, 120v rated variac (which weighs about 25lbs) you could charge 48V at about 20A. Something to consider would be a stepdown transformer in addition to the variac. For example, a 2:1 stepdown in addition to the variac would increase your charging capability to 40A instead of 20A and you would still be within the limits of the variac and a 20A, 120v household circuit. Of course we are talking about a stationary charger now.
Down side of any kind of bad boy/variac charger is it is easy to over/under charge and possibly damage something. You will need to keep a close eye on things while it is charging. It is doable, I've been running off my variac charger for a couple of months since my russco charger broke down again while I work on reconfiguring and upgrading the charging circuits and related stuff on the car to take a 240V-input Manzanita.
Good luck.
Discussion Starter #9
Thanks for the advice. For curiosity sake, if you charge four batteries in parallel @ 12V+, as opposed to in series @ 48V+, will the parallel circuit connecting them all make them properly balance while charging? In my head, they should. The advantage I see here is: a) a balanced charge, and b) no need for a charger on my bike. I could use the 12V 60A charger at work (I work in the shop at a commercial truck dealership) and have my own 12V charger at home.
G
Guest
You are right...for $200 why would I bother. I guess that's my biggest problem: I like to tinker too much. Where did you get your Select-A-Charge charger? I need something that fits on my bike because I need to charge it at work as well as at home.
Tinkering is a decent learning option but for practical purposes just get what you need. Since you really don't build things like this why go through the hassle. Once your machine is up and running if you decide to build a charger to better suit your needs then by all means do so. But make sure you have a good decent setup first. It does not have to be perfect but it does need to be functional and one that won't destroy what you have done.
I got my new charger from someone wanting to upgrade before they even used this one. It is perfect. Works perfect and if you really needed to take it with you it is designed as an on board charger. A car just happens to have more room. I am sure you can find a decent smart charger that will do the whole pack at once for a decent price that will be small enough and light enough for your bike.
Pete :)
Theoretically if you did put all the 12V's in parallel for charging, then you would not need to balance them amongst each other (should not be any different than charging one much bigger battery). However we are back at massive series/parallel switching to do that. One problem that might arise is if somehow a battery got way out of sync with the others during driving then when it was switched from series to parallel you would get a lot of current flowing to it as the higher voltage batteries charged the lower voltage one. So you would not be able to get away with anything small as far as the switches go.
I agree with Gottdi et al that there are plenty of economical options out there for you in the 48V range that negate the need for doing anything too terribly out there when it comes to charging. It is very handy to have onboard charging as well.
If nothing else is cheap enough, just find a used lester golf cart charger. They seem to run from 100-300 dollars on ebay.
Good luck.
G
Guest
Not so cheap but not terrible either.
http://www.batterystuff.com/battery-chargers/12-volt/marine-chargers/DPPS4.html
Much better and good for on board charging. Smart too.
http://www.batterystuff.com/battery-chargers/48-volt/multi-volt-input/SON4812SR.html
Better, smart and will do each battery for you. Good price. Smart as hell.
http://www.batterystuff.com/battery-chargers/12-volt/marine-chargers/GEN4.html
Why do you need to do battery switching with these chargers. You have four batteries connected in series but need to charge in parallel. Each output has a pos and neg so just hook up to each battery even though your pack is in series. Here is a test for you. Hook your batteries in series then with a multi meter go along and check each battery in parallel. Us the pos/neg terminal on your multimeter for each battery. What do you get, a reading for that battery only. If you connect a charger to that one battery you will only charge that one battery. Just keep your charger ungrounded from the body of the car and you should be just fine. Mount it on rubber feet for vibration protection and isolation. These are used in battery packs that are in series or parallel in the marine business all the time. No difference there or for your pack.
I like one single charger but these will do just fine. I actually have one for my Cushman. It is a 24 volt charger but has two outputs. Parallel or series.
The nice thing about the first and last charger listed is that if you want you can just use the darn thing in series as a single charger. Or you can connect to each battery if you prefer. Best of both worlds.
Pete :)
1 - 14 of 14 Posts
