Its a 2WD but automatic so I'm probably tossing the transmission with the motor, but the basic gist of the matter is the van has a very nice interior, and I have a title. Used cars are criminally expensive in my area, and the engine is blown again. It's the third engine the dealership put in there (warranties huh) and at this point the warranty ran out of time.
I've researched the topic quite a bit, and Astrovan conversions have been somewhat unfeasible in 2012, many forums opining the difficulty of battery capacity and a motor large enough to regeneratively brake a vehicle that weighs 4000 lbs when the electric conversion is factored in.
A decade later, batteries CAN be sourced at $100/kWh, and finding a used AC motor for basically free is not too difficult. I'd like some help with some of the general math and safety margins, although I am well practiced with repairing vehicles, and physics, I've worked in enough factories to know that there's a huge difference between theory and practicality.
To that point, I have calculated that a roughly 60kW motor should take the van up to around 50 MPH, but I assume something around 80kW is a lot more reasonable.
Reasonable efficiency suggests I could get a 50 mile range with 35-40 kWh of LiPO4 batteries, but once again, when factoring in AC conversion from DC, and the efficiency of whatever beefcake VFD powers the 80kW 4 or 6 pole AC monster.
So I'm fairly well aware it's a bit of an undertaking for a first conversion, but jumping into the deep end is a frequent habit. Basic specs suggested by math are as follows, please feel free to call me a fool and correct me.
35 kWh of LiPO4, exact arrangement depends on voltage and current requirements of controller
70kW 4 or 6 pole AC motor (probably an old Siemens motor)
Some VFD, here I need a lot of help. I am very familiar with some crane and machine VFDs, but those don't have capability for regen-braking, and I wouldn't even know where to look!
Likely to be direct drive (a dream of mine) but I do realize the regen braking from a 4000lbs vehicle is INTENSE, basic physics calculations suggest that any reasonable amount of breaking power is likely to generate 60-80 kW, which is a lot of power. I have been known to make large capacitor banks, so that may be a decent way to dump current from breaking and bleed it into the batteries, but also LiPO4 batteries are very capable of high current.
