That explains your measurements; makes you wonder how they use that circuit to determine that insulation has degraded.
All the circuits on the HV side will need to be traced and drawn up to get some idea of what is the purpose.
Need to know the pinout of that orange connector too, looks like 4 inputs with 2 blank pins between each one..?
Yes it makes sense now. So my first draft of the circuit diagram is not totally wrong except that there is this 51kohms resistor and some 11nF cap between PCB ground and car ground.
I know that on cars equiped with DC charging interface, the insulation monitoring device must be disconnected at least during charging session because insulation is tested and monitored by the charging infrastructure. So apparently on Volt Gen1, which was not equiped with CCS or Chademo, IMD is always connected...
Yes on the orange connector you get x4 inputs separated by two NC pins as follow :
I didn't detailed the "after HV relays" inputs in my diagram because I supposed these are only used to check a welded contactor or a similar feature. This part of the circuit is not used for isolation measurement. The three right AQW216 (supposed) photomos are used for this part of the circuit. (
@piotrsko what is the year of BECM you have ? because this part of the circuit whas apparently removed after 2013)
The three left AQW216 (supposed) photomos are used with the components described in my draft schematic and linked with HV inputs directly coming from battery pack (before HV relays)
I suspect this pcb to be at least a x4 layers board, so it makes reverse engineering a bit more tricky.
