1 - 7 of 7 Posts
I am offering 3.6kW Chevy Volt Gen 2 charger with everything needed to put it in a DIY conversion.
Charger is tested and works well. Needs to be controlled by 100Hz 85% duty function.
It comes with next items:
AC connector with 2m cable
DC Connector with 1m cable
LV Signals connector with numbered wires ready to be installed.
I can add prepared NE555 circuit for 100Hz charging signal. What you need is BMS to terminate signal when full.
Located in Slovenia EU. Shipping possible with Eurosender 30€ for EU residents. For others will need to check...
330€ + shipping. Recieve payments via Paypal or bank wire. Send PM.
I am selling because i found out it works up to 400Vdc and i need a charger for 104S setup.
More data and pics here:
viewtopic.php?f=25&t=1690
Discussion Starter · #2 ·
I have charger prepared to be connected directly to battery and AC. It needs only 12V signal for charging start. No fancy uC controller necessary.
Though I would recommend you have a BMS which can trip 12V relay so it can stop the charger at the top.
Discussion Starter · #7 ·
hello, can you please advice how can i set up chevy volt charger for my 250v battery pack?
Hi
I have tested charger at 180Vdc and it wouldnt work. I dont know what would happen at 250Vdc. This charger was tested from 320Vdc to 388Vdc.
Here i documented my case:
1 - 7 of 7 Posts
