Folks,
I have a HALL effect sensor that is putting out 2.5-5v for current measured within 200A range (proportionally). BMS is designed to work with a different sensor, that's rated for 750A, also putting out 2.5-5v.
So I need to adjust the output from 200A sensor, so it looks like 750A one using a formula like this
Vout = (Vin - 2.5) * 0.27 + 2.5.
This is easy enough to do with Arduino, using analog I/O. I was thinking about analog way, using op-amps. Has anyone done anything like that ?
