Well, things have changed a bit with more research.
I'm going to use a control board from Paul for a 2013 Leaf inverter, which I will use to drive the corresponding motor. Another member gave me the files for an adapter plate that I will use with the leaf motor, and I'll use a splined coupler to connect the motor shaft and the transmission input shaft.
I think that will give me the best power on a budget. I'm waiting on some quotes to mill the adapter plate, and I'm pricing everything else right now.
I'd like to get an entire Leaf for the battery pack, so I'm watching auctions right now. That'll probably wait into next year, but I'll work on getting everything else together for a test. This is a much more promising direction than earlier.
