21 - 24 of 24 Posts
Discussion Starter · #22 ·
Dear all
Many thanks for your input. It's all useful to me.
I know many of you have commented on battery options, but to be honest my biggest issue is finding a suitable inverter/controller for the motor. And also the programming of the controller.
In the grand scheme of things the battery options are pretty straightforward to resolve.
Do any of you more experienced EV gurus have any ideas to solve the controller conundrum?
Again, any and all suggestions will be gratefully received.
In some ways, yes. But winter range of EVs is only moderately reduced. If average power consumption by a car during use is 10 kW (20 kWh/100 km and 50 km/h average speed) then even 2 kW of heater operation is a 20% range hit.
You won't keep the windshield clear in an Alberta winter with only 2kw of heat. Bringing back nightmares of my commute home from work in my LEAF. Shivering under multiple layers using the heater only enough to clear the windshield so I could make it home before running out of battery. The LEAF heater would max out at 6kw and the air coming from the vents is luke warm at best.
Although the original poster did ask where I was from...
ScobiBTW which part of Canada are you in?
... this thread is not about Alberta weather. So just to clarify, then hopefully move on...
This comment was not intended to precisely define the power requirement for EV heating, but the 2 kW value is reasonable.
The maximum power allowed for a portable space heater plugged into an ordinary household outlet is 1.5 kW, limited by 80%of the 15 amp circuit rating. A full-blast space heater is comparable to a car heater in normal use.
The size of furnace used in small travel trailers is 12,000 BTU/hr input which is 3.5 kW. These furnaces are relatively inefficient, so only 2 kW of heat comes out of them. A car is much smaller than even a modest travel trailer but of course the trailer isn't trying to defrost a windshield.
Of course the most direct example would be the electric heater used in an EV that doesn't use the air conditioner as a heat pump. While they have more than 2 kW peak output (apparently the Leaf's 6 kW is common), as an average power use in typical winter conditions here, 2 kW is reasonable.
21 - 24 of 24 Posts
