I'm seeing all these awesome college projects and I'm very envious that this a thing you can do.
and with regenerative braking
If it is fun for you, the do what you want.
For most DIY projects, this means a higher expense and a higher amount of effort than they care to put in.
It's trendy to fantasize about regenerative braking, but realistically you're adding ZERO miles to your highway range, and only 5-10% to your city driving range. Generally, on the cheaper side, you're better off ignoring regenerative braking and just adding that extra range as more batteries.
Though if you're using an AC/BrushlessDC motor and a controller that can do regenerative braking, there's no reason not to.
Regenerative Braking severely limits your DIY options, especially the cheap ones.
The kerb weight of the vehicle 1600 Kg
Weight only matters in an electrical sense (ignoring handling and all that), for the energy you spend getting it up to speed, and, correspondingly, the energy you waste when you stop it. It has (nearly) no impact on your range when driving a steady speed.
http://www.enginuitysystems.com/EVCalculator.htm <-- Here is a calculator.
Punch in your weight and target speed, and then read the top "Inertia" result. (Aerodynamics has no impact on this, ignore that stuff). That tells you how much energy you waste stopping from a given speed. Note that it is not linear.
For a 1600kg car:
- At 100km/h: 171 watt-hours
- At 50km/h: 42 watt-hours.
That's a quantity of energy, and amount. Every start and stop from a given speed wastes that much energy.
A single 18650 battery has about 10 watt-hours, so, roughly speaking, you're burning through 4 of those every time you stop at traffic lights, or, 17 of those every time you stop from highway speeds.
Weight isn't that big of a deal compared to aerodynamics.
As a top level question what size of motor and what battery size would be required to give a top speed of 60MPH
Go back to that calculator I linked, and play around with the data. (Acceleration should be zero'd out unless you're testing acceleration, the calculator is a little odd to presume the values it does).
To know how powerful a motor you need, you need to know roughly the size of the vehicle, how much air it's pushing out of the way. That will tell you how hard it is to maintain a speed. Any extra power in the motor tells you how fast you can accelerate up to that speed.
Just to ballpark motor size to maintain 60mph:
- Around 8,000w, 11hp for a motorbike.
- Around 12,000w, 17hp for a small car.
- Around 50,000w, 66hp for a big van or truck.
Then, how long it takes to accelerate will depend on the weight. 0.2g is considered "aggressive" and 0.3g is considered "dangerous".
To figure this, the "acceleration" (also used for hill climbing) number for 1g is 9.8. So for 0.2g (0-60 time of 12 seconds, fast but not reckless acceleration), punch in about 2 there.
That changes your power to about 100,000 watts, or 136 horsepower to have "aggressive" acceleration. Most DIY electric vehicles will just have normal day-to-day abilities, not streetracing abilities. You decide.
The thing with electric motors is that their limits are generally only thermal. So you can overdrive them 3-10x what their continuous rating is for a couple minutes before heat builds up. That makes them well suited to most driving conditions because, as you can see, your power use when accelerating is about 8x your power use to maintain that speed, which only takes a few seconds. (17hp to travel at highway speed, 136 horsepower to aggressively accelerate to that from a dead stop).
If you want to go cheap, any 9" - 11" diameter DC forklift motor can do this. You can usually pick one up for Free-$200 if you're polite. It will weigh around 200lbs. Ignore whatever the label says it can do for power, if it's around 200lbs, you can get at least a hundred horsepower out of it. Duncan drives his to several times that, and it took him 7 years of actual racing before it took any damage. No regen though.
If you want to spend some high-hundreds or low/mid thousands of dollars, a Nissan Leaf motor is 120hp, a Tesla is 220-600 hp. Those can also do regen.
The motor will probably be rated for 36-48v, doesn't matter, you're going to give it at least 100, if not 175v or more. It will almost certainly be fine.
Go back to the calculator. Zero out acceleration. Punch in 60mph. Look at the "watt-hours per mile" result. Multiply it by 60 if you want to go 60 miles.
Anywhere from:
- 150 wh/mile for a motorbike.
- 250 wh/mile for a small and sporty car.
- 350 wh/mile for a normal sedan.
- 800-100 wh/mile for a van or truck.
You'll be looking for around a 20,000 watt-hour pack. That's what a Nissan Leaf has. Teslas start around 60,000, up to 100,000-ish.
Damien on his 1000euro build (including the price of the vehicle) said he can regularly pick up OEM lithium vehicle packs for $600. Damien has good luck, so, expect to pay 2-3x that perhaps if you're not as skilled a bargainhunter.
Do not use lead-acid batteries, they suck, and unless you can get them for free they are more expensive than buying used lithium ion batteries for equivalent performance. There is no reason to use them.
Any help gratefully received - have to start somewhere !
You'll need a controller too. You can build a big one yourself for around $600 for parts. Something salvaged probably isn't good enough. If you go OEM, that will obviously work fine.
Here are some nearly-identical threads with the same info:
http://www.diyelectriccar.com/forums/showthread.php?t=194601
http://www.diyelectriccar.com/forums/showthread.php?t=195105
http://www.diyelectriccar.com/forums/showthread.php?t=195706
http://www.diyelectriccar.com/forums/showthread.php?t=195826
Keep us updated with your questions and progress.
