Dear Tyn,
I think there are at least two reasons for grounding I think (not an expert in this domain thought):
- to ensure that an isolation failure is noted/secured, either by a Ground Failure device (when on AC) or fuse (when on DC) all metal parts with electrical connection must be grounded to a common point
- To avoid stray currents leave the motor via the bearings and the drive shaft, potentially leading to bearing failures (and remember, that might even be as far away as in the diff!)
Hope this helps a bit, regards,
Huub
Huub
