Hello I'm new, and it's my first time writing in a forum in general, if I do something wrong just tell.
I have an ems system on my car and issues to control my idle motor, wherever settings I change o how I do the wiring nothing changes.
The motor has a 3 wires connector, 1mass 2 pos. Whe its no voltage the butterfly stays in midle pos (actually it's not a butterfly it's a kind of excentric hole thats makes bigger smaller)
If I connect direct to a batt to one wire once get 12v it get a hard hit and open full. Same to the other pos wire but closing complete.
I'm wondering if I can make an instalation with one or two potenciometers/ relays and control my idle manually inside of the car.
Its for a track day car so it's one of the lasts opcions before remove and open more the butterfly.
The ecu only controls 2wires motors so I only can work half to open or half to close I try both I can get a more or less stable idle but I only can change changing ign and afr settings, not idle settings.
Will be great have click potenciometer when its cold and parking you put a bit more etc..
