Hey all!
Vehicle: A 2001 chevy tracker in excellent condition, donor vehicle that I got for 600.00 it has 50k miles on it. The current motor may have a cracked block, or just a bad headgasket. I havent dug into it yet but it shoots antifreeze through the spark plug hole when I turn it over.
Skill level: advanced with tool usage and ability to follow instructions, moderate automotive experience (wheel bearings, brakes, tune ups, suspension, never rebuilt an engine), metal fabrication some experience, no welding exp.
Range: Perhaps 30-40 on a charge.
Performance: full freeway speed (80mph) comparable to a 4 cylinder engine
Money: I would throw 2-3k at this project no question because the value of the vehicle is about 3k running. Getting into more than that I start to question return on investment.
Parts: I have considered 12volt batteries just to decrease the number of places I have to stash battery.
Charging infrastructure: I live in San Diego, we are seeing an increase in charging stations in the community. I would also want to charge at home in the most efficient way possible. I may consider solar panels for net metering if it made sense.
Anyone have any recommendations on a complete kit? parts list? If this is doable?
Any input on my return on investment concern? I think this is the largest barrier right now. Let's say I am charging at 0.14/kwh, and it takes 11.5 kwhrs to equate one gallon of gas in fuel economy for this particular vehicle, I am calculating this at $1.61/gallon of gas equivalent. So (gas currently at 3.70-1.61) at a current savings of $2.09/20 miles I am going to have to drive a lot of miles before I can recuperate the initial investment. Something around 50k miles, which at 30 mile charging cycles is something like 1600 times, which is about 3-4 battery sets as well, not even accounted for in the initial investment. I know this is offset by cost of ICE routine maintenance, however I really dont see the cost advantage unless EV owners are aware of something I am not considering, anticipated resale value of the vehicle? Exponential increases in gas prices that will hedge the investment?
Thanks!
image of vehicle http://i.imgur.com/7h1Nu.jpg
Thanks!
