I have had 2 mantis tillers given to me over the years. I got one running enough to till the garden once. Then it died and the giver wanted it back. The second I could never get going. I had an old and worn craftsman miter saw that wouldn't cut straight any more and the handle was broken.... sooo.... I built my first E(v)T?
here is the washer thing that held the blade on the saw motor. It happened to be the perfect size for the tiller adapter.
I welded the saw washer to the tiller adapter and it fit perfectly on the saw.
saw motor test fit on the the tiller
mounting plate made and mounted
Issues:
there are only 3 small bolts mounting the motor the the mounting plate.
one of the 4 corners of the mount on the tiller broke. There are only 3 small bolts hoding the motor on now
I have no idea how long this motor will last in this kind of use.
the tiller goes backwards now. There may be a way to swap some wires to get the motor to move backwards but I wouldn't even know where to start with that.
Issues:
