What do you want to do, and how fast do you want to do it?The flat 6 in a unimog produces 142 Kw or 190HP and 610 NM torque. What sort of elctric motor will match that. Or maybe a combination of motors?
Gazz
Sent from my STV100-1 using Tapatalk
Gazz
I just want to match the existing capabilityWhat do you want to do, and how fast do you want to do it?
I am thinking of building an RV type arrangement using a unimog flatbed truck, removing the motor, fuel system and tanks and using the existing drive train but running it all with electric motor (s). I thinking a li ion battery system augmented by solar pannels across most of the roof to top up the battery bank.That's very vague. Are you using it as a truck or a tractor? How far/long does it need to go? Unimogs are used for all kinds of tasks from log trucks, snow plows, trailer pulling or mobile powerstations by way of PTOs and hydraulic outputs.
There are plenty of electric motors that can get the job done for you. But that is not where the power really comes from. Consider the motor an extension of a transmission. The actual power is produced by the battery pack.
Let us know what you want/need to do. The first thing to figure out is the battery pack, then the motor(s).
realistically about nine ton overall weight. The truck is about eight ton with a diesel configuration. The range about 1500Ks with a mounted diesel generator as a back up.Now, were getting somewhere. What do you expect the final weight to be and what are you looking for with range?
I think I will look for a light truck to reduce the amount of power required.I don't recommend this conversion for a first timer. 1,500km on battery alone is currently impossible. Traveling at highway speeds with this weight will take over 100hp (75KW) on flat ground.
General rule of thumb for cars when planning batteries for range is 100Wh per 1000lbs per mile. Nine tons is 18,000lbs, so at least 1,800Wh per mile. A Km is 0.62 miles, so 1116Wh/Km. Your range of 1500km would require a minimum of 1674KWh of energy. A used Nissan Leaf battery pack is approximately 20KWh and sells for about $5,000 US. You would need 84 of those battery packs for a cost of $418,500 US.
If you go minimum on your battery pack, and depend on the generator you will add weight and complexity. A standalone Generac 80KW genset weighs 2,425lbs (1,100kg) without the fuel tank or enclosure. The primary traction motor to sustain highway speeds would exceed 200Kg and a single Leaf battery pack would weigh similar to the motor.
You can't do much to change the weight of this vehicle, but if you adjust your range goal down a lot, we might be able to help you.
Actually this Unimog (S404) tops out at 55-60 in some cases. You are thinking of the heavier u900/406 models that at max RPM of 2800 - max out around 45 mphFlat grade. Unimog portal axels top out at around 45mph. It can carry 2 tons but I don't use it for hauling big loads. Maybe 1/2 -3/4 ton of cargo at most.
Joe - Did you end up converting your 404 to electric?Flat grade. Unimog portal axels top out at around 45mph. It can carry 2 tons but I don't use it for hauling big loads. Maybe 1/2 -3/4 ton of cargo at most.
Direct drive to the large Unimog tires for use at low speed? The required motors would be ridiculously large. If you used appropriate reduction gearing it would work, but would you basically throw out everything that makes it a Unimog, or would you build custom axle assemblies with the motors mounted to custom axle beams, retaining the portal-geared hubs? Those custom axles would be a major project.If one were to eliminate the engine and entire drivetrain and somehow implement a direct-drive system per wheel, how feasible would this now be w/ a Unimog 404 today? How powerful would each motor ideally be?
