Yes, I guess I should lay out my performance goals. I want to use the AMR motors because of their power curves. I used Desmos to whack together a crude calculator to analyze performance(found here:
Curves ) , and I found that this specific layout meets my goals quite nicely, with a little extra bonus. My goals going in were:
180 mph top speed
2.5 second zero to 60
At least 100 mile range.
I was looking at an 80kwh battery bank, but I haven't settled on what batteries to use yet.
However, looking at the power curves I found something which is very nice indeed: namely, acceleration stays pretty much constant throughout the full speed range of the car, at about 10 m/s^2. This is assuming 95% drivetrain efficiency, though, so I'm obviously not expecting those results in the real world. Still, that kind of acceleration means 7.5 second 0-170 times, which is fantastic. I feel that the calculator is definitely flawed in that the power draw at low speeds is really low, giving me ranges that are much too good.
4 AMR racing motors produce about 737 continuous horsepower, and 1622 peak, which may well actually be too much for an '82. What would be the limiting factor there? I'll have more of a look at battery packs, but I'm planning to supply the inverters at 700 volts to decrease the current draw. Do you have any suggestions as to potential batteries?
I thought for a while about using a larger motor (AMR 250-90 dual) on the rear axle, but I couldn't find a way to get that to meet my goals without using some sort of transmission, and those are very underdeveloped for electric cars at the moment. The reason Tesla uses AWD for their high performance EV's is because they couldn't get transmissions working reliably, so they went to a different gearing for the front and back.
I found some Tesla Drive units at StealthEV, I'll run the numbers for those.
Also at Stealth EV I found my motor controllers: Cascadia Rinehart PM250Z's. And they are ludicrously expensive, at $13,000 apiece. And I would need one per wheel. I'll have a look at the Tesla Drive units.
