Hi. I am running an AC51 motor with Curtis Controller 1239E and 144v battery pack.
I know I should be running HV DC fuses from traction battery to the charger, heater, DC/DC converter etc.
Does this look correct?
Traction Battery —> (FUSE - DC High Voltage - 600v 30 amp) —> DC/DC converter
Traction Battery —> (FUSE - DC High Voltage - 600v 12 amp) —> DC Heater
Traction Battery —> (FUSE - DC High Voltage - 600v 30 amp) —> ThunderStruck EV 2500 Charger
Also I only have one fuse in the HV traction battery pack (in the front engine compartment). I have read some people have one in the rear battery pack as well.
So would this be correct?
Rear Traction Battery pack negative—> (FUSE - DC High Voltage - 150v 400 amp) —> Front Traction Battery positive
Front Traction Battery negative —> (FUSE - DC High Voltage - 150v 400 amp) -> shunt
Cheers!
Cheers!
