Correct rating for my main fuse 72v system, Altrax 450-amp controller
1780 3
The ANL fuse in my VW has blown. It is a Wilderness EV Kit #2 that I purchased along with the car from the original owner. I believe the fuse blew simply because one of the rivets contacted the connector on the motor controller -- not terribly well laid out I guess.
I would like to replace the fuse but the documentation is conflicting. The wiring diagram indicates a 500-amp fuse, the pictures of the kit parts indicates a 450-amp fuse, and the fuse itself is a Littelfuse 400-amp @ 48v fuse. Because the system is running at 72 volts, I do not know what the Amperage rating was actually specified for the fuse. Also, the documentation refers to a "slow blow" fuse, which sounds bad. Shouldn't it be fast acting?
Advice appreciated.
1 - 4 of 4 Posts
Admin: 'one of many'
Can't help on the fuse rating.
Advice appreciated.
From what I gather the fuse should be a slow blow.
The reason for this is that you wouldn't want a quick blow fuse breaking at just on 450A when you are climbing that steep hill, over taking a slow truck, at max power from the controller.
The slow blow would give you a little breathing space for short bursts of maximum accelleration without blowing immediately.
1 - 4 of 4 Posts
