I was testfitting my coupler, and there is a bit of wiggleing when it is lined up on the transmission spline. It is not a ton, just a bit of a wiggle if you shake it with your hand. This is (i think) because the clutch disk's grooves that fasten arround the splines are a bit worn from use. It is the stock clutch disk for this tranny. I ended up using the clutch disk to make the coupler, but im worried about the slight wiggle room.
Is there a way to minimize the wiggle room?
Is this dangerous?
Im getting a precision adapter plate made so everything will be perfectly centered, so i think that will help the issue
Is this dangerous?
