Last week, the salvage 2014 Leaf arrived for my Superbeetle conversion. The front is pretty bashed (radiator support almost touches the drive stack) but the car can move around on its own.
When I plug in the trickle charger that came with it, the car starts beeping a lot and all three charge indicator lights on the dash flash. The user's manual says the flash code means:
"When the temperature of the electrical plug is too hot, or the EVSE is unable to detect the temperature of the electrical plug, check that the electrical plug is connected correctly. If it is connected normally, stop use immediately and contact a NISSAN certified LEAF dealer."
The plug latch mechanism is broken off at the connector, if that matters.
Any advice for how to start troubleshooting?
thanks,
---mike...
thanks,
---mike...
