I have been thinking recently about how I could implement the Honda IMA drive system into a single motor.
I was thinking mainly about how to optimize packing and power density. With water cooling, I don't see why you couldn't pump 300+ amps per module. According the ornl chart on the 05 accord hybrid, that would equate to about 150-200 ft-lbs. A stack of 5 of them would be close to 800 ft-lbs that weighs in at close to 200 lbs and that is about 13 in long. Not bad. Let's try to improve on that.
Physically. we could chop off about 50 lbs from the extra aluminum from the case and shrink it to 9-10 inches long. If we remove all of the individual stator bobbins and machine down the lip on the rotor and fit them together, we could have a 'continuous' motor. Here is where I have a couple of questions.
What is the best way to make a continuous stator segment and the drawbacks of doing so?
On the rotor side, would the individual magnets in the rotor interfere with the magnetic field of the rotor as a whole? Connected together of course.
Is there any benefit to making a continuous motor, vs just connecting the individual segments, besides the physical benefits?
EDIT: Also the rotor laminations are taller than the stator laminations, so I don't think it would be feasible to make a continuous motor. There would have to be at least a 1-1.5mm space in between the modules. So would stacking them together with that bit of space between modules make a big difference?
It uses a segmented stator which makes for an easy rewind using flat wound magnet wire
May be possible to pump coolant through the stator provided you could keep it sealed and prevent it from leaking onto the rotor.
