Curtis 1221 R
6773 Views 11 Replies 5 Participants Last post by  kangoofarad
Hello,
i'm rebuilding a 1221R curtis controller.
I'm looking for the datasheet of SR4180R 1 diode / motorola....
it's a two plate monuting similar "to220" with rounded diode insered in....
thank's
1 - 12 of 12 Posts
Take a picture of the part because I can't find it, nor does it seem like a valid Motorola part number (Curtis likes to use Motorola dual-diodes with a common anode).
An example of a valid part number would be MUR1620CTR - the CTR suffix is important is it indicates the rectifier is a Center-Tapped, Reverse configuration.
hello , I've found the name of the case,
its "to-220 button"
see view one:
http://61.222.192.61/mccsemi/up_pdf/MR2400FR-MR2410FR(TO-220).pdf
your "MUR1620CTR" is a dual diode....not good for me!
mine is single, anode on pin 1 (left view front)....
no data-sheet found at this time:(
I think it is about 200V / 40A , but its imposssible in to220 normal case!
bye
Sorry - can't help you. Your original part number is not a valid one for rectifiers; it cross-references to a crystal oscillator.
You will need to be able to determine what the diode is doing in the circuit - is this one of the freewheeling diodes, for example? - and then pick a substitute based on the controller's ratings.
Also, it is quite possible to have a 200V/20A rectifier in a TO-220 package as long as the Vf is less than 1.2V or so and the total thermal resistance from junction to heatsink is less than 3C/W.
yes it's for free-wheel. and regenerate too.
with 300A of current in max braking ,there are 12 diodes (and no place for more), it need 25A minimum...each:confused:
I've used the MUR2020R in 1221's (and other early Curti) and they will work, despite a lower 20 amp current rating.
I honestly am not recommending them, but there is simply no other alternative that I am aware of.
These are still available, but probably won't be for long as they are the reverse polarity of their FAR more common cousins.
http://www.onsemi.com/PowerSolutions/product.do?id=MUR2020R
Cheers
Mark
I also have used the MUR2020R sucessfully. I am also working on an idea where I will use TO242 diodes which are not reverse and mount them sideways above the original TO220 location. Then I can use short jumpers from the appropriate leads the board. The only drawback is that they must be insulated from the heatsink. Just an idea.
Hi for all...
recently , one of sr4180r diod flashed on road...:eek:
diod replaced but curtis desn't works any more...
there was a flash on board next to...
i found a wire conductive on board cutted , an ic lm358out of arder too...
It works on table now , except the "drive" solenoid command who turn off after throttle..!
It's too , i'm powerless in front of this problem without schematic of this card.
It's the card with molex connect and 4 opto's on....
if neither some body as ever work on, i'm interested;
and excuses my poor writing english level!
thank's
For update....
I found faultly capas 0.1µF everywhere!
after all replace at new , it's ok:p
For update....
so, re-comming there for new bad adventure:rolleyes:
friend's curtis has decided to burn out at power on moment.
Worked well day before....
Not glad at all to repair again these 1231r models....
no more good news with a full schematic there....?:unsure:....
or if someone can give a mink or , experience with....
our need is a serial motor controller , in sep-ex wiring
eventualy with the marvoulous recuperation mode on brake foot....
as the original 1221R from curtis....
we think the recently change of battery techno,
pb or ni-cd , to lithium, with less of intern-resistivity,
even with same nominal voltage, 96v,
can cause dammage to these controllers,
cause the more important power to dissipate ,
(Vin-Vout)xI...
so , new model , or repair original , will see the max direct current,
max reverse current,and max brake current, 2 half reduced ....
good news , curtis saved , tested and re-bult on car!
the fault was cumulated dusty inside , dammage on isolattion pad , between bus and pcb.
A dead npn transistor mps750 of low branch push-pull driver stage,
and photo-flashed rc components....
Current value revised to low (1/2 approx) by A limit pot ....
to follow...i hope no;)
1 - 12 of 12 Posts
