new guy here, converting a 1958 BMW Isetta (micro car 700#) to EV. I have a Curtis controller 1234se and 2 Tesla Batteries (48 volts) Turned system on for the first time, I have error code 73 on the controller. The motor runs slow and goes in forward and reverse, I understand #3 bad crimps but I have no idea what #4 problem with power supply for the motor encoder is. Anyone have a good idea on where to start the trouble shooting?
Things people miss on the 1234 when it has a motor stall code.
1. The 4 pin molex connector for the 1313 handset is in the harness instead of being on the controller.
2. It is possible to hook the encoder up backwards from the motor rotation and this will cause a stall code.
(Swap pins 31 and 32 if this is the case.)
3. Power for the encoder is pins 26( +5V) and 7 (-)
4. I know for a fact that the 1234 has to be reprogrammed when certain motors are used because I just did a dozen warranty claims for Hangcha over that very issue.
How I would test to see if the phase rotation of the motor was backwards from the encoder
-Test for 5 volts at 26 and 7
-Get the drive wheel(s) off the ground.
-Swap pins 31 and 32
-Make sure the drive wheels are off the ground.
-Test.
If no change, you might need a reprogram
If it ran at high speed , grab a beer.
