Hi! Greetings form Poland!
I installed a used curtis 1234se to Fiat Panda(2010) conversion by polish energy company "Energa".
I bought this car with a damaged inverter and repaired it 2 times but it broke again. Their inverters are faulty, motherboard is a junk...
The car has PMSM motor and 32 LiFePo4 Thundersky cells.
I have a 1313 console for programing.
sin/cos sensor is RLS RM22AC and throttle is connected.
I can't start characterization procedure for PMSM motor because of this errors:
CAN Startup fault
CAN PDO Fault Dual Slave
CAN PDO Fault Pump Slave
Throttle Signal Open/Short
I think it's because it's VCL programmed. Is it possible to remove it from firmware?
Please help!
CAN Startup fault
Please help!
