Questions
-Did you contact Curtis with your motor part number to get your set up values or did you do the "AC motor Characterization procedure?
-Throttle type?
-Number of encoder steps on motor ( its in the spec sheet)
-Number of steps the controller is set for ( "Encoder_Steps" is in the motor menu )
-Is the "MotorTemp_Sensor_Enable" turned on or off ?
-In the Monitor menu is "Motor_RPM" the same value as "Motorspeed A" and "Motorspeed B" when motor is turning? ( all three need to be the same )
-In the Monitor menu what is the maximum value for "Throttle_Command" and "Mapped_Throttle" with accelerator fully depressed?
-Throttle type?
