1 - 4 of 4 Posts
Folks,
I have a Curtis 1236SE in a project using a 5K throttle (Type 1) because it's a retrofit into an existing machine, which has such throttle. Problem is throttle is connected one leg to common ground, the other is the signal wire that goes to the original motor controller. Curtis controller calls out that pot low shouldn't be tied to the ground, so it's not possible to use the original setup one to one. Running an extra wire is of course doable, but is quite difficult due to the nature of the machine (boom lift). So the question is if there perhaps another way to wire the pot throttle to those controllers where one of the wires will be tied to either bat+ or bat- ? I don't see a way in the docs, they suggest pot wiper / pot low are protected against short to bat+ and bat-, but perhaps I missed something.
Thanks!
Hi....I bought brand modern Curtis 1236-6406 controller from ebay to my ev venture (70's Scaled down), but I can not get it running. Any offer assistance would be exceedingly acknowledged, I think this would be best gathering to ask. I have PC get to to controller in OEM mode. There appear to be a few kind of VCL program preprogrammed in controller. Connected are blunder codes, to begin with one is steady and moment comes when throttle is pressed. Should engine run indeed on the off chance that there are mistake codes present? Would it be conceivable to evacuate VCL code from controller with 1309/1314 OEM connection? Is there a few data accessible how engine parameter recognizion ought to work?
www.7pcb.com
I have a hard time decoding your message in full, but I will try my best to offer a suggestion. Since the mystery VCL can be interfering with your setup, it's better to reflash the controller with some generic version of the OS from Curtis that behaves strictly according to their docs. That comes with some cost though - out of the box Curtis doesn't support things like speed and/or acceleration profiles, and even reverse. Then getting that OS image from Curtis is like extracting a CIA agent from a gulag.
I would have to check the docs on whether present conditions would prevent the setup from working. I think it depends on whether they're warnings or errors, I will follow up on that later.
1 - 4 of 4 Posts
