Two contactors? I only see one, labelled as "MAIN CONTACTOR". The coil is shown near the upper right (that's how the controller controls the contactor); the contacts are in the lower right (that's how the power is switched on and off so the controller input and one terminal of the motor are not always live).I bought a curtis sepex 1243
Im looking at the wiring diagram which can be seen here
I have a few questions
what are the two contactors for
Well, through a fuse and diode, but no resistor. Why would you expect a resistor?And just to be clear, all of those switches are wired right into the positive end of the battery? No resistors needed?
