Why?????Started building it, please consider thread closed.
I stared at yours a lot while thinking about patterns. Space constraints made me shy away from duplicating it. I do not think I can get the posts in at all in the 90 degree configuration you show, I believe I will need to make my connections parallel to the pack face. My assembly process is currently to install the 6 rear modules, wire/bus-bar/sensor connector them together with their two long wire leads attached. One of the leads for the + will have the main relay already on it. Wire/bus-bar/sensor connector the two packs of 10 with the long cable and the main lead wires between the packs installed. Lower the 6 pack and shell over the 20 pack and connect the 6 pack to the top of the 20 pack just before it goes all the way in. Secure everything to the shell. Flip it all upside-down. Reach in between the 10 packs and secure the main relay then make the two main connections to the external main connector. One of the connections is - neg and the other is + but after the relay so "dead". I had also considered placing a temporary frame on the top of the 20 pack to hoist it into the shell, but I am more concerned with stressing the bus-bar connections and lifting the 200# of batteries than flipping it over after the batteries are secured to the shell. I have a hoist...Would this work:
http://www.diyelectriccar.com/forums/showthread.php?t=181490
Or do the power terminals end up in bad spots?
