1 - 20 of 283 Posts
Update 2012-06-15
Project page, with all the pictures: http://www.eternalmachinery.com/ecar/
I recommend starting at the last page of this thread to see if anything interesting has been going on.
Riding motorcycles made me realize how unnecessarily cumbersome cars are. But cars have a couple nice advantages, like keeping the rain off. I'd like to build some kind of minimal vehicle with two seats that I could commute in - 35.2 miles each way, and they recently put in charging stations at work. Minimal frontal surface area, weight, drag. I've done a lot of inconsistent babbling about different possibilities here. I have basically no relevant experience, so this would involve a lot of learning. My goals are unreasonable. People with far more reasonable goals give up all the time, so I recognize it's entirely possible I'll never build anything. Most recently I've been thinking something simpler and easier yet still extreme might be good (this thing is tiny):
Update 2011-03-16
Range goal: 100 miles (70 mile commute round trip + headroom).
Aluminum monocoque body, TIG welded by me (I've never welded).
NetGain Impulse 9 motor.
12 6v Trojan T-105s = 10 kWh, in pontoons.
Rear wheel drive.
Even weight distribution per tire.
Motorcycle rear end.
Custom double wishbone front end with push rod actuated inboard coilovers and sway bar.
Front center of rotation about 2" below ground (single rear = ground level rotation center).
Clearance: 6" (high, for aerodynamics).
Original post:
Motorcycles made me realize how incredibly unnecessarily cumbersome most cars are.
Height: 89 centimeters (35 inches).
Length: ~4.3 meters (14 feet).
Width: ~2 meters (6.5 feet).
Seating capacity: 2.
Based on this kit:
http://evolveelectrics.com/72%20Volt%20Lithium%20Electric%20Motorcycle%20Kit.html
22 Thunder Sky 90 amp lithium cells (yellow) (very interested in suggestions).
Not shown is the vertical sheet of metal running most of the length of the car on both sides for structural support. Same concept as the Lotus 25 (first F1 monocoque).
I am very interested in suggestions. I'm far from solidifying anything. Except maybe the seating position and wheel layout. It might be possible to talk me into a tube frame.
My commute is about 30 miles. I want a range of about 100. I actually got a poll at work including asking if I'm interested in ability to charge my car, but of course not counting on that happening.
I need to read up more on the watt hours and ranges of existing vehicles.
Motors generally are listed with maximum volts or something. And that seems to be based on some often unmentioned amount of amps. So am I right in thinking the actual maximum ratings of motors are more related to watts (which I realize is volts x amps)?
I was thinking four wheels, then realized / remembered how much less gearing is involved with one rear wheel. I want something that's less maintenance than a chain, capable of handling more power than a belt, and less inefficient than a shaft or hydraulic final drive. Surely using gears for the final drive would be somehow bad (even if I mounted the motor on the swingarm near the frame).
I've also thought about two wheels - less resistance. But I think the convenience of low speed stability is worth the extra wheel.
Tilting is tempting. "Cars lean the wrong way in turns." But I think with this geometry, tilting wouldn't gain me much.
I want to wrap the upper (suspension) wishbones and steering rods in fairings.
It would end up getting registered as a motorcycle due to having three wheels. I'm not sure how difficult it'll be to register in New Hampshire, US, but I think not too bad.
Where can I get wheels / tires around 26" tall and 3" wide, and 30" tall and 6" wide?
I have effectively no experience, but this is all stuff I'm very interested in learning. And I realize figuring out how to get sheet aluminum into that shape and welding it together is a lot of learning. Anything I should know about, other than hammering and English wheels? I don't even have any idea what type or thickness of aluminum is appropriate.
The grey box in the middle of the front suspension is the charger.
Of course I'd prefer a custom molded canopy, but I think cutting flat sheets of safety glass (worst case: cut up used car windows) is going to be much more obtainable.
I'm thinking motorcycle type handlebars, with a single rod running to a lever attached to the steering (old(?) drag racer style), and motorcycle type (un-powered disk) brakes. Doing three independent brakes is tempting (one for each foot, one at the left hand, accelerator at the right hand) for control, but I think I'd prefer just doing a single brake pedal and an accelerator pedal for convenience.
I've been playing with related ideas for a few years: http://www.eternalmachinery.com/
I would be the last person to tell someone they can't do something (I live by the anything is possible philosophy) but you are talking a HUGE step; for any type of automotive project. You said you are willing to learn, so it is possible. With your experience/knowledge level, you will spend much more time learning than you will building. There are a handful of scratch-built, and serious custom, projects here on the site. I would recommend you read the entire threads of each before you do anything. You'll not only see the vehicles being built, but kind of experience the challenge from the builder's perspective. Pay attention to post dates. Many times you will see long gaps between posts. Sometimes it just takes a while to catch your breath; sometimes it's figuring stuff out, finding stuff, etc.
Any scratch-built, or serious custom, project is an enormous challenge; mixing the EV aspect in doubles the complications and hurdles. I'm not trying to discourage you, just prepare you. The worst thing in the world is getting knee-deep in a dream project, only to find it's a nightmare, and running out of drive. You can find them in classifieds year-round, every year. You'll see phrases like, lost interest, no time, been sitting for months/years, etc. That usually means it wasn't what they expected, and they're bailing out. The TV shows make it look glamorous, and the challenges almost fun to overcome. In reality, even in multi-million dollar shops, it is incredibly exhausting at times.
All that being said (can't say you weren't warned ;)) - it is the greatest experience ever! :D I've been doing custom work for nearly three decades, and am in the midle of my first scratch-built project. In my thread, I said a few times that it will likely be my last - no way! I already have ideas of what I would do next, and none of them go back to simple modifications of pre-existing vehicles. If I were to use one, it would still be scratch-built except for the original shell. In fact, I even started another one already - an e-bike!
You can also watch some of the conversion threads to see the hurdles they faced, and how much effort went into solving the issues. That'll give you an idea of what just building an EV takes. Just try to be honest with yourself about how far you're willing to go/how much drive you'll have when it's gets challenging.
Regarding your specific plans, rolling and shaping a metal body like you have planned is pretty intense. That is a serious craft to learn in and of itself, and you're planning to try to learn and master it while building an EV from scratch - big bite, don't choke! There are fiberglass belly tanker bodies that would put you in the neighborhood. Google it - one company that I know has them is Rod-n-Race. I have no experience with them, have considered purchasing from them but didn't, heard good and bad reviews from previous customers...
Automotive glass is a pain to deal with. The windshields can be cut, but even really experienced glass shops will tell you no guarantee - it might break. Don't even think about cutting the other windows - unless you like sweeping up tons of glass chips! Tempered glass can't be cut, it shatters.
If you have motorcyle type steering on a vehicle that size, it's probably going to be VERY heavy! An automotive rack-and-pinion, and steering wheel, would be better.
That doesn't look like nearly enough batteries to get decent range, and I wouldn't want them between my legs! :eek:
toddshotrods: Thanks for taking the time to reply. I realize this plan is ridiculous. But I fail at avoiding taking things to extremes. There's nothing short of this I'm interested in doing.
And I think attempting to make an aluminum monocoque should make a fine hobby for a couple years. Maybe without compound curves, and using a fiberglass nose and tail - I need to see what that looks like. And then the batteries will cost less.
I have read through the turmoil of a number of complete custom ICE builds, and some electric conversions, for years.
Thanks for the term "belly tanker", some sexy stuff. Looks like Rod-n-Race is in the middle of a web site move, and not in archive.org.
I guess I don't see why the steering would be heavier than a big motorcycle. Heh, perhaps because motorcycle steering works entirely differently.
Hi Darxsus
Go for it - making it yourself is fun
Have a look at Human Powered Vehicles and Solar cars for how to go fast with minimum power.
A couple of points
Non leaning vehicles - look at height of center of mass and vehicle track
For decent cornering you need to be low or wide
Low is frightening on the road, do you need to know what company makes truck diffs?
A leaning machine can be narrow and high
What is wrong with belt drives? I have seen some transmitting several hundred horsepower
A folded aluminium or sandwich chassis would go down well, for the body parts have a look at the mould-less fiberglass system Burt Rutan used on the LongEze
...Low is frightening on the road, do you need to know what company makes truck diffs?...
That's priceless! :D
...I realize this plan is ridiculous. But I fail at avoiding taking things to extremes. There's nothing short of this I'm interested in doing...
Good, we speak the same language. If I don't kick the bucket, I'll be around to help you find the best way there (extremes). Just wanted to point out the challenges, and see how you responded.
...I guess I don't see why the steering would be heavier than a big motorcycle. Heh, perhaps because motorcycle steering works entirely differently.
Quads, ATVs, four-wheelers (or whatever you want to calll them), and many reverse trikes use handlebars so it can work. I based that suggestion on the fact that you have the battery pack up front and said you want enough batteries for a 100-mile range. I don't know what the actual numbers would be, or even the weight of the batteries you mentioned, it just seems like enough batteries for that much range would come with a weight penalty. That would require more effort to turn the wheels. Even a really fast rack and pinion would give you more leverage.
I'm an electric reverse trike fan so I dig it. Yep, sure will be a ton of work, but if you're persistent you can see it through. Not what I would recommend as a first project, though. But hey, you gotta find your own way. Good to be talking about "years". I'm in the second year of my project.
How about a couple suggestions?...
-The extremely laid back seating position is going to be real uncomfortable I bet. So maybe something a little more upright? You might want to think through how you'll get in and out of it, too.
-Looks like a fairly slippery design and the wheel pants are cool, but I see you have an open suspension which wouldn't be very aerodynamic. I'm not concerned about it on my project, but then I'm not looking for a lot of range, either. So maybe aircraft strut-like suspension parts or cover it?
-Also, the trailing edge of the wheel pants look neat, but they'll probably limit your turning radius if the pants are turning with the wheels.
-Trikes are considered motorcycles in most places, so your "glass" can be plexi - much easier and cheaper to deal with.
-I wouldn't be surprised handlebars would work out on this. I'm going that route and will be mounting the parts in the next several weeks so can let you know how well it works. I have a rack and pinion out of a 914 Porsche as my plan "B" if I need it.
Do you have a nice, big welding/frame table to lay it all out? Probably going to need one.
Good luck with it. I'm looking forward to seeing it come together.
Interesting drawing and concept. Its like a two-place bobsled, but even more cramped and uncomfortable... ;^) Seriously, its cool and you should build whatever you want to.
Before you get too far, though, you ought to check out your state DMV to see what the licensing regulations there are for your motorcycle class. In NY, a trike seat has to be 20" off the ground, so your design won't be registerable (or insurable) for the road here. You need to avoid off-road (ATV, motocross bike) parts in a lot of states, too. It would be a shame to build something you couldn't got on the road...
Take a look at (Google) Dave Malewicki's California Commuter trike from about 30 years ago. He was on a similar wavelength as your trike. Its a proven and record-setting design, and plans are still available. Buying a set of them from him would get you a long way up your design learning curve for very little money.
Just my $.02.
TomA
Discussion Starter · #9 ·
Web page is: http://www.eternalmachinery.com/ecar/
Yikes, I missed comments.
I've been thinking a lot about aerodynamics. On and off for years. Basically, the consensus seems to be that a teardrop / wing / airfoil shape is the most aerodynamic. I believe, and finally found evidence, that that shape is only used because a pointy leading edge causes sudden and complete loss of lift at varying angles of attack, none of which concerns me. More here:
http://www.eternalmachinery.com/mostaerodynamic/
The human / battery swap was because I was having difficulty with the vertical asymmetry. I'm likely to play with the previous layout more.
My biggest aerodynamics question is: Is it better to give the air a long, smooth path, or a shorter, still smooth but more sudden path? Specifically as it relates to air flow around my head. I'm guessing for this application it doesn't matter that much. The potential problems are skin drag and boundary layer separation (flow becoming turbulent) over longer distances.
I also squared off the sides to better fit the vertical structural reinforcement panels that go in the sides.
Duncan:
Actually one of the recent steps in this process was looking into the feasibility of creating a highway bicycle for my 35 mile (each way) commute. Turned out I would need to be awful close to a world record holder - and they're on groomed courses.
This design involves nothing between my my butt and the pavement but a single layer of sheet aluminum. The 7" of clearance is negotiable. And I want it as wide as is practical. Maybe I should go a little wider. I'm comfortable with being within licking distance of fast moving pavement.
I've done motorcycle track days a few times. Good stuff. I once slid across the front straight at Loudon NH, watching my bike spin along with me. It was great fun, seriously. This is relevant in two ways: I really am comfortable within licking distance of fast moving pavement, and I'm really disappointed with the failure mode of motorcycles. A little too much throttle, a little too much lean, and a pavement transition, and suddenly you're on the ground. I felt betrayed.
Thanks for the tip on belt drives. Got any links? I fear a very wide belt would be necessary, and aerodynamically inconvenient.
toddshotrods:
Yup, and you were right about the number of cells. I upped the count to 56 (Thundersky 90 amps), which comes out to 395 pounds. Yikes.
fishguts:
I don't see why the extreemly laid back seating position would be uncomfortable. Maybe I should try sitting in a mockup for a couple hours before I start fabricating. (I'm interested in mockup material suggestions - I probably just need to look for myself at home depot.)
Yeah, I've thought a bunch about front suspension fairings. I've played with a couple possibilities, but keep wondering if it's really worth it. Largely because F1 cars don't seem to bother, although I don't know if that's one of their annoying rules (like outlawing turbines and CVTs because they don't sound as entertaining, really). Also, it's a feature that can wait until absolute last. And minimizing half-sprung mass can be good.
You see I chopped off the trailing edge of the wheel pants (I like that term). Didn't seem worth the un-sprung bulk.
It would be great to be allowed to use acrylic, but I worry it wouldn't take long for it to get annoyingly scratched up by highway gravel. I wonder how well they buff up. Any experience with acrylic windshields?
I look forward to hearing how your steering turns out.
I have nothing. Except space and time.
grayballs: Awesome canopy link, thanks.
TomA:
I think of it as cozy :)
I really like the idea of the body panels keeping me snugly in place.
I actually just emailed the DMV today. Sucks to hear about that 20" limit.
Thanks for giving me Dave Malewicki's name. I was familiar with the vehicle and looking for it recently for obvious reasons. I also was not aware he was selling kits, good to hear.
...I don't see why the extreemly laid back seating position would be uncomfortable...
The problem is you have to look forward at the road, meaning your neck would be bent forward. Could be a strain after a while. Recumbent bikes do it though. Every person is different. I like being tucked in a crouching position on motorcycles, while some people would find it extremely uncomfortable...
Hi Darxus
I used to ride a recumbent HPV (Human powerred vehicle) but it was a two wheeler the few times I borrowed a trike it was great fun but very physical
With a couple of inches ground clearance (the chain goes under your bum) you have to lean your body into the corners and you are so low that other road users can't see you
A leaning machine is better and becomes more stable the higher it is
Saying that I can relate to the wheel going away from under you and the bum hitting the road - better than the head!
A leaning three wheeler should avoid that the failure would be a skid
The racing HPV's are normally very low but going higher and having just the wheels below the beast will not have a big drag penalty
Wheel spats
If you are serious about low drag you need to look at the solar racers
If you have a shape that the flow doesn't separate from (stream-lined) then the old CD x area no longer applies
At this stage it is the "wetted area"
So it is better to go wider and build everything into your aero-body
Getting a decent body is not that difficult - the devil is in the details around the holes for the wheels and canopy
How long were you allowing for your commute?
The HPV record is now over 50mph - normal bikes its about 35mph
It would not take much power assist to get a semie-streamlined HPV to cruise at 35+mph
(Two wheeler HPV with nose and tail fairing)
A fit guy (not me) could do it by pedal power
Angle of Recline
Much better than the face down method the motorbikes use
You will need a head rest - or neck muscles like a bull
You really have three ways to go here
light weight (50lbs) low power 50 - 150 watts
pedal + electric
or
200+ lbs, 400+ watts light weight electric+
or
Mini Car
1000+ lbs, 30+Kw
Ah, thanks. Laying flat in bed with just my head propped up while using a laptop for hours makes my throat sore from the angle. I think sitting up this much wouldn't be a problem. Definitely worth considering, and testing.
Discussion Starter · #13 ·
titling and inspection requirements in New Hampshire
Less than twenty-four hours for a response from the NH DMV:
If your looking for certain specifications there are two websites you can refer to. They are
www.gencourt.state.nh.us/rules/state_agencies/saf-c3200.html and
www.gencourt.state.nh.us/rsa/html/indexes/default/asp
At the second website you will be looking for RSA 266:1. That will take you through all of the inspection requirements as well as the first website being our rules for inspections. If you have any further questions you may refer to State Police at 603-223-8778.
If you need further assistance please do not hesitate to ask.
Thank you,
Brandy Stone
Division of Motor Vehicle
Inspection/Dealer Desk
Direct link to RSA 266:1: http://www.gencourt.state.nh.us/rsa/html/xxi/266/266-1.htm
You'll just have to experiment to see what's comfortable for you. As illustrated, you'll be just looking over your knees - that's pretty laid back for sure. Would be a neat low profile, but an old bugger like me is wondering how the heck you'd get out of that thing! ha ha Person in the back seat better be real skinny!
But I do like it - sleek, cool looking.
The plexi windshield will hold up fine (unless you race on a dirt track). Plexi usually gets scratched when people clean it with paper towels. A soft cloth is what to use. Most of my experience with it is with boats, so that's a different world, but look at all the motorcycles out there with plexi fairings and windshields. It's also easy to form. I can tell you how sometime if you are interested.
Put a long rod through the driver's head indicating his line of sight. Right now he's looking at the stars - nice view but I'd be beating him in his bubble head if I was her, telling him to watch the road! :D Now rotate the head and rod, from the shoulder/chin area, until the line of sight touches the surface at a point about the length of the entire vehicle in front of it. That will give you an indication of how much you'll have to crank your dome forward to see where you're going. You;ll also see how much you're stretching your neck to see forward.
If you try doing a real-life mock-up you have to be reasonably accurate with the measurements. Get some boards from the local hardware/home improvement store and duplicate what's in the model as closely as possible. You'll want something solid like wood, so it won't give and allow you to subconsciously shift it into a more comfortable position. Put something small (like a pop can) on the floor a vehicle length in front of the nose of your vehicle and see how long you can stare at it before fatigue sets in. What you want to be conscious of is mental fatigue, more than if you think you're comfortable. If you're uncomfortable, you'll stop and get out. Not very much fun though, if it happens every fifteen minutes. On the other hand, if you begin to experience serious mental fatigue, you start endangering yourself and others on the road.
I have neck issues. If I sat in that car for five minutes I would have a migraine, but I have been on motorcycles with low clip-on bars for hours with no problems. It's all relative...
Join me on IRC (Internet Relay Chat) in ##ecars on irc.freenode.net (no typo, two #'s).
If you're not familiar, this protocol is older than the web, and used by lots of people. Instructions are here: http://freenode.net/using_the_network.shtml
It works best if you can stay connected 24/7.
I just noticed that the world record for an electric vehicle is 555.6 km (345 miles) in a Daihatsu Mira Van with no apparent interest in aerodynamics. Anybody want to sponsor me on a battery pack? Seriously. I'd get moving much quicker.
Looks like I'll be building a mock-up out of 4'x8'x7/16" chip board for $15 each, the cheapest stuff I found that seemed sturdy enough. Should I go with the cheap option of only getting one, cut down the middle lengthwise, and holding it together with scraps in the barn that my house came with, or at least $80 (including truck rental) to start a more extensive mock-up?
I'm thinking the one board will give me all I need, since I have a detailed and easily manipulated computer model, and I just need to make sure the space is tolerably large enough for humans.
Looked through New Hampshire law, and what looked applicable of federal law. No major problems, for which I am very thankful. No problems from the state. The two annoyances are, of course, from the DOT.
All glass (and acrylic / plexy / etc., collectively called "glazing") is expensive due to extensive safety laws, specified in an ANSI document that I have to PAY ($60) to be able to read: ANSI/SAE Z26.1-1996. Flat glass is expensive. I expect curved glass to be silly expensive. This seems to me to be a significant barrier to development. I really don't see what laws need to apply to an acrylic windshield, other than "Visibility must be at least Z." And possibly "Won't break if you drop an N pound rigid object on a section X"xY"".
Looks like being classified as a motorcycle is going to mean putting controls in the standard motorcycle places: Front brake and throttle on the right handlebar, rear brake at the right foot. I'd prefer right foot throttle and left foot brake. But I think I can deal with that one.
But other than that, no significant change of plans. :D
toddshotrods:
Yup, this is why I need to build a mockup. Humans are complicated. Thanks for the point on mental fatigue. I love the feeling of riding a motorcycle in a crouched position, and I've thought about using that, but I really can't see how I could remain comfortable without any support from the wind. My SV650 has race handlebars and foot pegs. Makes the interaction with the road much more intimate.
http://www.chaosreigns.com/gallery/Darxus_SV650_with_Woodcraft_bars_and_high_pegs.jpg.html
...Looks like I'll be building a mock-up out of 4'x8'x7/16" chip board for $15 each, the cheapest stuff I found that seemed sturdy enough. Should I go with the cheap option of only getting one, cut down the middle lengthwise, and holding it together with scraps in the barn that my house came with, or at least $80 (including truck rental) to start a more extensive mock-up?
I'm thinking the one board will give me all I need, since I have a detailed and easily manipulated computer model, and I just need to make sure the space is tolerably large enough for humans...
That one sheet should give you enough, combined with the scraps you have, to mock up a stable seating arrangement. I would use smaller pieces that can be easily attached and relocated for other critical elements. Foam and poster board with masking tape are good too. I like using them because they're cheap. You can build mock-up motors, batteries, etc, really cheap and try different sizes, locations, configurations.
Another thing you should do is solidly box in your foot space. See how it feels when your feet absolutely cannot move outside the confinement. Likewise a couple pieces screwed on to keep your elbows and hips confined. Allow for any padding, and maybe glue some cheap upholstery foam on it to get a real sense of things.
This may sound crazy to people who are conversion oriented, but it's a crude form of how the vehicles you're converting were developed. We tend to take for granted the engineering that goes into developing personal transportation.
...All glass (and acrylic / plexy / etc., collectively called "glazing") is expensive due to extensive safety laws, specified in an ANSI document that I have to PAY ($60) to be able to read: ANSI/SAE Z26.1-1996. Flat glass is expensive. I expect curved glass to be silly expensive. This seems to me to be a significant barrier to development. I really don't see what laws need to apply to an acrylic windshield, other than "Visibility must be at least Z." And possibly "Won't break if you drop an N pound rigid object on a section X"xY""...
They might be annoying, but they prevent some really bad things from happening. The biggest issue is how the material breaks. Tempered saftey glass shatters into thousands of little benign glass chips. They can cut but not stab and slice. Windshields are made of regular glass with a plastic film in between that keeps the glass from dislodging and becoming a weapon (other than being a nice place for your head to stop its forward momentum). Tempered glass would be horrible on the windshield because all those chips can aim straight for your eyes, open mouth, etc.
Plastic also breaks in different ways. Plexiglass, which was once common, breaks like normal glass into shards that can puncture and slice mercilessly. Lexan doesn't, and is the standard material used for racing applicatios. It really does make a huge difference what you use.
You also have to dig deep enough to see which if those requirements relate to a specialty car in your state. In Ohio, we have a LOT of freedom. They mainly check basic safety equipment. We have to have receipts for every piece that is used to build it though.
Have fun! :)
Looking at your preliminary design I think your passenger will be very uncomfortable sitting in such a confined position and not being able to see past the drivers head. What happens to the driver’s control of the vehicle if the passenger lifts their knees or moves their arms as they would tend to do a lot if they are uncomfortable? The laid back position of the driver also means that their elbow joint is almost straight. What does this do for their range of movement and the forces they can comfortably generate at their hand to move the steering. How much could the handle bars move forwards while steering the machine before that hand had to let go due to range of movement issues. Can you afford to let go with hand controls?
I would consider using a 60% laminar low drag body. The higher the percentage laminar the more the thickest section of the body moves aft. This will help with packaging and aero at the same time. Rather than using a pure body of rotation consider stretching the top half vertically for better packaging.
For aerodynamic stability consider increasing the side area aft of the centre of gravity. Objects in motion through the air the centre of pressure will try to follow the centre of gravity. As for considering the angle of attack irrelevant consider what happens when the car encounters a cross wind or turns a corner. A 10MPH cross wind at 35MPH would cause about a 16 degree off axis wind direction besides the pointy front end could be dangerous to pedestrians. I believe the EV1 was designed to be most aerodynamic at 10 degrees off axis wind direction.
The attached sketch is something I drew a couple of years ago. You may find it interesting.
Admin: 'one of many'
It's interesting just how shrink wrapped some of those HPV's get. Some have taken to using a camera and video screen to navigate and gone
windowless in pursuit of the ultimate slippery shape. My concept is a behemoth in comparison. One of those HPV's hit 80 MPH on just human power (1/4hp?).
The thing that really derailed the idea for me was the glass windows that would be required to get it legal in NZ. Another difficulty is windscreen wipers are mandatory and must wipe at least 70% of the screen in NZ. I'm sure glass could be made for a price. Getting it optically clear and distortion free through that tight and changing bend at the front and with its compound curvature it would be exceedingly difficult and hence prohibitively expensive. Coming up with a system to effectively wipe that screen and not disrupt the air flow (such as parking inside the A pillar) would certainly be challenging. The concept was also just a bit too in your face for me.
Note the 60% laminar profiles that wrap the wheels and people pod and how they allow the wheel pants and pod to be fairly short at the rear without resorting to a kammback. Note how the rear passenger can look over the driver and both can lean forward to some degree. This should help make the design less claustrophobic. I wanted the design to be reasonably large in profile at least so that it had some presence on the road and other vehicles would see it.
1 - 20 of 283 Posts
