Used but excellent like new condition.
Davies Craig 12v EWP115 Nylon Electric Water Pump Short: Part Number: DC8125
I have 4 units. Asking $120.00 USD each.
From the manufacturer:
Davies Craig Electric Water Pumps replace and out-perform all existing belt-driven water pumps available today. See an increase in cooling capacity while freeing up valuable horsepower.
The 115 L/min (30 GPM) EWP115 model is rated for normally-aspirated, unmodified V-6 and V-8 engines up to 3.5L (213 CID). The composite nylon body weighs just 2.2 pounds, and the brushless motor draws only 10 amps at full flow. Inlet and outlet fittings are designed to fit 1 1/2" (38mm) ID coolant hoses.
The "Short" includes the EWP115 Nylon pump body assembly only. Inlet and outlet adapter sleeves hose clamps, and wiring harness are all sold separately. If you want to use adapters other than those normally included with the standard kit, start with this "Short" and add just the adapters you want. The "Short" also makes an economical spare or replacement pump for an existing installation.
