1 - 7 of 7 Posts
Hi need advise 🤔 I have a old forklift motor I need a Brushed DC speed controller for , a 45v RPM 1900 RTG 1/4HR winding COMP Electric motor, using 4x110AH 12v lead acid batteries ,
Also there's a picture of a speed controller I already have but can't get it to work for some reason
Would be grateful for any advice to point me in the right direction 👍
Hi it's going into a MK1 Nissan Micra ,direct drive to the crank ,so all I need is a speed controller for the motor , but getting nowhere at the moment :'(
So the Nissan Micra is a tiny car. Do you have the motor connected directly to the transmission? I’m assuming front wheel drive here. Kelly Controller has some decent offers you could use as does Curtis. Not sure anyone is supporting or even building Series Motor Controllers anymore. Hunt for a decent used one.
If you are looking at something you can build and tune, here is one option:
There are many threads within this grouping, but MPaulHolmes let the effort to create an open source brushed DC controller. Buried within the many threads you'll find the PCB Gerbers, schematics, and software. If you want turn-key, please kindly disregard this message.
1 - 7 of 7 Posts
