Sorry if this has been discussed before. I have an Alta electric motorcycle. The standard charger is basically an Elcon/TCCH PFC 2500, with Can bus controller, in a different case. Right now to charge, when owners can't connect to the grid, people are using generators or a battery pack with an inverter. In the past I have powered Vicor power supplies with DC. The input basically goes right into the rectifier, so if you hook it up right, DC will just passes through the rectifier and moves on. I was wondering if I could do the same with an Elcon/TCCH charger? It would basically save the step of converting from DC to AC and then back to DC.
Thanks for the help.
Bluefxstc
Bluefxstc
