Duh! I should have just Googled it!
"DC Rule of Thumb
For those switches that list an AC voltage rating only, the "DC Rule of Thumb" can be applied for determining the switch's maximum DC current rating. This "rule" states the highest amperage on the switch should perform satisfactorily up to 30 volts DC. For example, a switch which is rated at 10A 250VAC; 15A 125VAC; 3/4HP 125-250VAC, will be likely to perform satisfactorily at 15 amps up to 30 volts DC (VDC)."
https://www.carlingtech.com/amp-hp-volts
Check 'em out, (Carlin Technologies) they have lots of good/interesting info.
https://www.carlingtech.com/switch-learn-more
https://www.carlingtech.com/basic-circuit-function
https://www.carlingtech.com/contacts
https://www.carlingtech.com/switch-type
Here is lots more interesting info:
https://www.sesko.fi/files/671/EV-charging_standards_may2016_Compatibility_Mode_.pdf
https://forums.anandtech.com/threads/ac-switch-vs-dc-switch.1746006/
https://answers.yahoo.com/question/index?qid=20100803163938AAr07sw
https://cr4.globalspec.com/thread/44970/AC-Switch-in-DC-Circuit
"DC Rule of Thumb
