Today I removed the engine from the donor car. I had to pull it and the transmission together. I think in the long run it is better to have the tranny out to make the adapter plate and so forth. I took lots of photos and will happily share them. In order to disconnect the half shaft axels from the gearbox I had to disconnect the lower ball joints and steering tie rod ends (I think that would be necessary on any front wheel drive car). Subaru utilizes a roll pin that goes through the inboard end of the CV joints to hold them on, this was the last thing holding the engine/transaxle in the car. I made a support to lift from by spanning four of the W trusses in the garage twith a piece of inch and a quarter schedule 40 water pipe. I put a two foot piece of five sixteenths chain around it in the center, securing it with a cap screw and nut, and put a half ton hook on it. I hung a half ton comealong by the cable hook and attched it to the lifting eye on the top of the engine with a shackle. I was able to lift the engine from the car easily. I put the ball joints and tie rods back together put on the wheels. I took the car off the jackstands and moved it back a coulpe of feet and then I was able to lower the engine onto a dolly. Then I separated the transaxel off, and removed the clutch and flywheel.
I fabricated a contraption to keep the axels from flopping around when the car was moved about. I used a piece of three quarter inch copper tubing that was the same length as the end to end measurment on the spline stubs protruding from the transaxel. I used a piece of flatbar I had laying about and attched it at the points where the center suport for the eingne hooked on. I held the copper pipe onto the flatbar with a plumbers two hole strap. I chose copper because it is much softer than the splines and won't damage them.
60.9 KB
69.1 KB
68.2 KB
67 KB
66.2 KB
63 KB
37.9 KB
52.5 KB
64.6 KB
46.7 KB
