Isn’t is safer and easier to source to use solid insulation material of the correct thickness and cut it into the correct shape?
If you want a more accurate approach, probably having some dummies 3D printed is cheaper than buying modules, even dead or near dead ones (depending on the reason for their state).
The 3D model is already available on the diyelectriccar Grabcad https://grabcad.com/library/tesla-model-s-battery-module-1
