1 - 2 of 2 Posts
Hi all,
I've crunched some numbers using the formulas here.
Originally, I was optimistic about these numbers, until I double-checked them against another calculator here.
I'm confused. Is there a reason the wiki's calculation for power uses 1/2 the density of air, instead of the full density? I'm not claiming to be an expert or anything, but because of the substantial number difference I was getting I wanted to confirm. The second calculator also has a hard-coded slope, which will definitely affect the numbers as well.
Going to go back and run my numbers again making sure I didn't make a mistake.
Drag losses are due to the energy required to move the mass of air around, and so it is governed by the equation for kinetic energy which is 1/2mv^2.
And before you ask, the reason why the wiki equation has v^3 instead of v^2 is because it is power which has an additional velocity factor. Think about it this way: if you double your speed, the power you need to overcome drag goes up 8 times (2^3) but it only takes you half as long to get to your destination so the energy you use only goes up 4 times (2^2)
1 - 2 of 2 Posts
