Hi,
we are building a Porsche 914 conversion, using battery modules from a Porsche Taycan.
We use the Hyper 9 motor 130V version, so our HV is limited to 125V. That is 5 Taycan Modules in series (one module has 25V max).
To get more capacity we want to parallel 3 of these battery packs, which would be 5 Taycan modules in series and 3 in parallel.
One battery pack will be in the front of the car, the other two in the back.
So there is a problem with the BMS. We used the Orion 2 BMS system in our former builds but it's not built for parallel wiring as the manual says. So I would need 3 seperate BMSs - one for every pack. This would be quite expensive (~3,500€)
So I had a look at the Dilithium BMS, which will probably be the better solution. But there is one question regarding the configuration.
I attached 2 configurations that make sense to me. The first one will be the safest I guess, the second one would safe me one BMS unit.
In the first version I use one controller and one satellite unit for every pack.
In the second version I use one controller and one satellite unit for the front pack, and one controller and one satellite unit for the back pack, which is directly paralleled.
I don't know if the second version is possible, because there only the modules are paralleled, but not the individual cells in the modules.
What would be the best option to solve this?
Thanks
Alex
