Hi All,
Scratchin my head here....just installed a new set of Interstate 8volt GC8-HD-UTL batteries (9) and have about 500 miles on them. I originally had a range of about 25 miles, but this last week it has dipped to about 8 miles, which is luckily my total commute, but barely made it home
. I have noticed a lack of 'punch' when accelerating, and am curious as to why.
Here are some specs:
1992 Festiva
72 volt system with Alltrax 7245 controller
D&D Motors ES-15A Series DC motor
Quick Charge - Select-a-charge 20amp automatic on-board charger
when charged, the batteries are at about 1275 on Hydrometer guage
Battery water levels are good, I have been topping them off with distilled water when needed. (Have I put too much in? if so, how do I fix it?)
The charger says it is giving a 100% charge, and the pack voltage and individual battery voltages are withing expected range (about 81 volts for pack and about 9.0volts per battery when fully charged)
When driving, I typically pull anywhere from 40 to 200 Amps (300 max) (According to controller software)
Can I be overtaxing the batteries? Have I damaged them?
Can I be charging them too fast?
Also am having toruble telling if motor is binding to transmission, seems tight, and some squeaks at slow RPMs, difficult to tell if it is aligned or not.
Any ideas? I am not sure why this is happening. Pretty dissapointed if the batteries are going south. Any suggestions? I would really appreciate any help that you are willing to give...
Thanks in advance,
Steve (Iggymo)
1992 Festiva
Thanks in advance,
Steve (Iggymo)
