What brand of usb serial adapter are you using? and yes it sounds like a driver issue. The driver might be specific to the usb-serial adapter, Did the usb-serial adapter come with the controller? Maybe check with the controller manufacturer web site. win7 normally looks for the driver I thought . If you can get to the Device Manager window you should see a yelow triangle by the usb port that you have the usb serial adapter plugged into. It will/should say what the device is. Then you just( like it is ever that easy) need to find the driver for it. or it could be as easy as finding a generic usb-serial driver.
later floyd
later floyd
