1 - 1 of 1 Posts
has anyone had success actually changing paramters on a DMOC445 when using a tricked CCS file? i can connect with the DMOC using a tricked or hacked ccs file but the parameters i can see are not corresponding to the limits in the tables. it looks like the ccs file is causing this. i tried increasing max power and it actually went down and so forth.
my build # is B9-8F-B0-1A-98-63-1F-02 built in 2008.
thank you
1 - 1 of 1 Posts
