DMOC 445 Flash or ccs file
1661 Views 1 Reply 2 Participants Last post by  TIE1961
Hello,
I recently purchased a DMOC 445 controller that was set up to run with an AC90 motor.
I have an AC24 motor that I would like to run with the controller.
I got it all powered up and showed a GUID of BC-27-E6-DB-0B-BC-D2-27. However, I cannot find a .ccs file to run this guid. I also am unsure of the parameters of the AC24 vs the AC90. Is there a way I can just flash in an AC24 file with new GUID?
Any suggestion are appreciated.
Brian
1 - 2 of 2 Posts
I recently purchased a DMOC 445 II controller and need to set it up to run with an AC90 motor. Do you have the ccs file for the 445II controller?
1 - 2 of 2 Posts
