-ensure contactor driver PWM pull in voltages and hold voltages programmed correctly
-make sure the relay or switch turning on KSI pin is rated for batt voltage and at least 30A to be safe.
Oh sheesh... I was giving misleading info here that applies to the 123X controllers that handled their own precharge. I did not put 2 and 2 together that the 144V (with 12V logic that does not reference B- ) does not precharge itself as you only feed 12V to pin 1 (KSI).
Also:
-no enconomizers on contactors. No flyback diodes.
For anyone else building off this info I am not sure if these suggestions apply. The controller already may have the lower hold voltage as an option (so probably still no economizers?), and it appears the coil flyback voltage suppression is still built in to the controller as they show no other device across the coil.
Out of curiosity do you happen to have pics of your supplied precharge resistors and relays? I have a 144V 1239 that I will need to wire up soon and had not arrived at your predicament yet. I did not buy it as part of a package, it was at auction with one AC35. This thread has been helpful to me as I was going to get pretty confused when I went to build the harness from memory of 1238 96V. I already left a skid in my pants when I first went to power it up with a 96V supply (assuming it would still turn on at a lower than 144 voltage) and supply negative to B- post and I got nothing. I then learned of the 12V KSI and was sure I had fried it, but I guess the isolation from logic to battery circuit is pretty good, as it was ok. This suggests a much more reliable controller than those that reference B- for CAN, serial, logic etc as most of the broken 1238's I have worked on suffered from failures caused by big V spikes or major current events, cooking the logic circuit in some way.
Thanks, Brian! That makes sense. So, I’ll need 3 contactors right?
A contactor for the DCDC might be the easiest way, but as a cheaper option I set up my little truck's DCDC with a manual precharge and overnight park switch. The system was all wired with the DCDC getting constant power from the traction battery which meant the DCDC was on for probably a good part of 12 years (from previous owner design) and had died, also with the parasitic draw on the battery pack being undesirable. I put a momentary 15A switch from battery + to a chassis mount resistor in parallel with an LED, and all that in parallel with a larger lockable disconnect switch. My DCDC has pretty sparky inrush when connected to the battery so the precharge idea was to save the disconnect/overnight/storage switch contacts from pitting.
