Besides- my sign is accurate- the worst that would likely happen to them is they'd get a cardboard lightning bolt stuck to their chest.
Great to see you out there getting into it.Definitely the most fun track I have been on for years - despite the issues
I'm all ears!Great to see you out there getting into it.
I couldn't stand your steering ratio to be honest, way too much work, wanna cheap fix for that?
What is the current state of the hydraulics? Is itI have a power steering rack - it's about 2.8 turns lock to lock and not too heavy without the power - Subaru
Thanks Duncan.... It was grease lubricated with the hydraulics working two cylinders - to assist
I drained out the hydraulic fluid and cross connected the two cylinders - air and any residual oil can flow easily cylinder to cylinder
When the wheels are off the ground it feels about the same as any manual rack
That's pretty similar to our stock Spitfire, which has a similar front axle load, rack-and-pinion steering, a fast ratio, and no power assist. I'm fine with it, but some drivers are surprised by the high effort, at least initially.But because I only have 405 Kg on both front wheels it's not too bad
Hi Brian - whats the ratio on your Spitfire?That's pretty similar to our stock Spitfire, which has a similar front axle load, rack-and-pinion steering, a fast ratio, and no power assist. I'm fine with it, but some drivers are surprised by the high effort, at least initially.
I would have to dig the car out of storage to check, but it looks like there were two Spitfire racks, with 2.6 ("quick") and 3.5 (standard) turns lock-to-lock. Since the steering angle at the limit is impressively high (no CV joints to worry about), the steering is quicker than even those values would suggest, and with the short wheelbase the effect is dramatic. I will check, but I wouldn't be surprised if it is the quicker rack; on the other hand, we have 215/50R13 tires, which make the steering heavier than with the stock 155R13 tires.Hi Brian - whats the ratio on your Spitfire?
Yes, a mechanically slower mechanism is a way to reduce steering effort, but at the expense of having to spin the steering wheel even more.Duncan, in short you make up a simple reduction drive, overdriven in this case.
