Hey Duncan, any idea what motor volts/amps were at when it blew? Just wondering how much was too much for that motor. With your high voltage pack, what was your peak motor volts? I saw 1200 peak amps.
HiHey Duncan, any idea what motor volts/amps were at when it blew? Just wondering how much was too much for that motor. With your high voltage pack, what was your peak motor volts? I saw 1200 peak amps.
Coat those windings! Or get the arm. and stator dipped and baked at a motor shop.http://what-when-how.com/electric-motors/dip-and-bake-systems-electric-motors/
Megaohming the parts before and during the clean-up and re-coating process(es) would also be a good idea, since you're using it at such a high voltage.
You should have a word with a site administrator about thatOK
Only allowed to up load 10 files at a time
Yes, but Hitachi probably dipped it many decades ago. The varnish may have dried out, cracked, or been worn away by now. As well as a insulator, the varnish glues the windings in place to keep them from shifting around and chafing the insulation. That's probably what doomed your old motor.QUESTION
Dip or laqueur the armature? - I'm inclined to leave it the way that Hitachi left it
